It is currently Thu Aug 27, 2026 12:47 am
 Post subject: Mast base update
PostPosted: Fri Jan 04, 2008 3:32 pm
Well I did adjust the "Y" in the hull by lenghting the threaded "Y" by about 3/8 of an inch. I also saw that the plastic foot which forms the bottom of the mast base is cracked where it attaches to the hull and a white washer
appears to be loose under the mast base. I also noticed the hull protudes about 1/4 inch where I made the adjustment, I'll try to get a picture of the area later today. Is this protrution normal or do I have further problems?????????????
