It is currently Tue Aug 11, 2026 4:27 pm
PostPosted: Sun Feb 13, 2011 6:13 pm
I just bought new to me pro angler and was wondering what you guys thought of a rack I was going to buy used. Is a Thule 520 Kayak Stacker. I have a 08 camry and not sure if it would fit and how easy it would be able to load myself. Any help is good!
PostPosted: Tue Mar 01, 2011 2:30 pm
The thule stacker is way to short for a Pro Angler. The stacker is designed to help facilitate two kayaks balancing on their side. The pro-angler, if you decide to carry it on a Camry, needs to be right side up facing towards the back. Simple rack pads will be fine. It will be a bear to load but figure a way to slide it up the back and you will be fine.
bobby nabors
Florida, USA
www.LiquidSurfandSail.com
PostPosted: Wed Mar 02, 2011 12:43 pm
the gunwales of the PA are a decent place to put load also, but be judicious of sliding it upside down. You can allow it to rest on bars without much if any padding. I had three on my trailer for two years and carried the third upside down on the overhead rack. It worked fine and kept me from having a full length spread like on the hull down units. One bar was just inside the footwell behind the front hatch and the rear bar was mid tank well area.
Just pick your placement carefully and get help putting it up if possible. I only trailer mine ( I'm down to one yak for a while) now and while it isn't as convenient for getting on the road, it is really nice to load it up the night before a trip and only have to load the heavier things when I get to the water.
Good luck, Phill
