It is currently Tue Aug 11, 2026 2:22 pm
 Post subject: Front Lid Strap Issues
PostPosted: Sun May 29, 2011 11:36 am
My front lid bungee straps are starting to separate and was wondering if this is normal for a 2 month old or a design flaw.
PostPosted: Sun May 29, 2011 3:27 pm
One of mine is doing the same, but it is about 7 months old.
It hasn't broken, yet, so I will just keep using.
PostPosted: Sun May 29, 2011 4:01 pm
Likely causes: Over stretching, UV damage, rubbing against a sharp object or flaw from factory. Do you crisscross the bungees to the opposite pegs? If so, it could be from over stretching. Unlikely to be dry rotting so soon as I've had mine over a year now, stored outside, with no problem. Check the pegs to see if maybe a small bit of plastic wasn't trimmed as it looks like the rubber 'cords' has been cut. Could have been cut/nicked when the pull tab was stitched on and once you stretched a few have snapped.
MrGreen
PostPosted: Sun May 29, 2011 8:39 pm
The pegs are clean no burrs, yack stays inside, never criss crossed. The other side is starting to become this way as well.
It's a design issue, if so... What Does That Mean???
PostPosted: Mon May 30, 2011 11:56 am
Mine is doing the same thing and I first noticed it after I brought it home now both sides are doing it. It is stored inside garage and has only been out fishing about 6 or 7 times. I was curious if I was the only one with this problem.
PostPosted: Mon May 30, 2011 4:22 pm
Mine shipped from Hobie the last week of February 2011, possibly could be a bad batch of straps. Is this a warranty thing? If not what is this item # and who would stock them???
Hey Budlight, Where's the GATOR TROUT???
I know you're hiding them somewhere!!!
PostPosted: Mon May 30, 2011 7:24 pm
Can order the bulk bungee strapping by the foot from ACK relatively cheap then just cut it to what you need. I have noticed it on my '10 model that I got in February on the tackle hatch, but not on the front hatch.
PostPosted: Tue May 31, 2011 8:37 pm
Yup, mine too. About 13 months old, stored in the garage with lid not bungeed closed, light weekend use only. Hardly a heavy wear situation.
PostPosted: Wed Jun 01, 2011 2:58 pm
I highly suspect it is a simple (but obviously aggravating) supply issue. I use the heck out of my PA(s) and have owned one (usually 2) since they were first released with no similar issues.
When I am running catfish jugs the front hatch is my "cooler" for my catch. For convenience, I normally only hook one strap while I am fishing so the right one gets 20 times the use as the left one.
I have also made an accessory rod holder that I mount by hooking under both bungees to separate and hold a set of 8 rods for strolling crappie.
I actually also regularly use the left one as a tie off point for a stabilizer line for an otherwise shaky elevated camera mount on the bow.
Either way, I bet Hobie will address the issue and take care of you. I have not seen better customer care.
Let us know how it plays out.
Good luck, Phill Pittman
PostPosted: Thu Jun 02, 2011 12:03 pm
Yeah appears to have been an operator error where they stitched through the bungee. This has been changed already. Contact a dealer for replacement parts if needed.
PostPosted: Sun Jun 12, 2011 7:50 pm
Check into buying a high quality bungee cord that it could be replaced with, mine has shown no wear though and I have had mine for almost 2 yrs. and I USE IT ALOT. hope you get it fixed, bring it to the place where you bought it and ask them why.
Brandon Boren
