It is currently Tue Aug 11, 2026 10:35 pm
PostPosted: Thu Nov 29, 2012 1:05 pm
Hey everyone, I just became an owner of a 2011 Pro Angler and am loving it. :mrgreen: I fish mostly saltwater down here in Pensacola, FL and pretty much chase anyhting with fins.
My question is does anyone know if I can order replacement hardware form YakAttack for a gear trac? My PA came with two tracks mounted to the rails, and I am thinking of moving them to the mounting boards (or I may just buy two more, I really like these things....) but it didnt come with the screws/bolts since it is installed on the PA rail brackets. Or would it be easyier to just get some stainless bolts?
After I decide what to do with the geartracs I have a few other ideas for rigging . I may even try to put up some pictures.
Thanks for your help
2011 Pro Angler
PostPosted: Thu Nov 29, 2012 5:04 pm
most likely far cheaper to buy SS hardware at the depot or lows. even if the racks have the U-bolt attachments on the rails, you can still find those at the home stores.
cheers.
drew
Cathedra Mea, Regulae Meae.
PostPosted: Thu Nov 29, 2012 7:40 pm
Call Luther@Yakattack if you are ordering more. He may help you out. He's really a great guy with great products
PostPosted: Fri Nov 30, 2012 7:26 am
I would use the propper gear from yakattack as it will fit neatly into the mounting screw holes.
Unless you can get quality stainless 316 bolts or screws and check they fit propperly and still allow you to slide the track mount fittings into the track.
Have a browse through their site, this will give some good options.
http://www.yakattack.us/Products/Products.html
Geordie
West Ausie
