It is currently Wed Aug 12, 2026 3:07 am
 Post subject: Hauling the PA 14
PostPosted: Tue Feb 26, 2013 12:23 pm
Has anybody used the Yakima Hullyrollers and Mako Aero Kayak Saddles to load and carry a PA 14? I have a Toyota Sequoia am thinking of buying this setup. Also, any suggestions for locking the kayak on the top rack so it will be there in the morning when I get up.
 Post subject: Re: Hauling the PA 14
PostPosted: Tue Feb 26, 2013 6:55 pm
I have, and they work well. As far as locking them down, there are available locking kayak straps as well as locking lasso cords designed specially for kayaks. Google is your friend!
Hers a pic showing them on my truck
PostPosted: Tue Feb 26, 2013 9:49 pm
I am guessing some typical steel security ropes thru the scuppers or mirage drive opening wrapped around your supports would work for locking it down.
I have a masterlock python rope style lock I use for camping to lock up bins and stuff when away from campsite.
http://www.amazon.com/Master-Lock-8428D ... cable+lock
PostPosted: Tue Feb 26, 2013 10:01 pm
These work great to
Kayak Security Locking Cable from Lasso
http://www.lassosecuritycables.com/
PostPosted: Wed Feb 27, 2013 8:31 am
I use Hully Rollers on my Durango. I mounted them about six inches apart to conform to the center keel on my PA-14. That gave me better support and much more control when loading/unloading the boat. I use two ratcheting cargo straps to cinch the boat down to the racks, and a front tiedown rope to hold the bow down at freeway speeds. The boat never moves.
Here's the first step in loading it. Note how the bow sits firmly between the rollers. If they were farther apart, the narrow bow could slide to either side when the stern is lifted.
Pro Angler-14 owner
PostPosted: Wed Feb 27, 2013 8:17 pm
Thanks all for the input. it looks like this setup will work on my Sequoia.
PostPosted: Thu Feb 28, 2013 4:46 am
Hondo, check the posts by TDK on this forum for his setup. I just did the same thing using a Showboat as well and it is flawless IMO.
PostPosted: Thu Feb 28, 2013 3:50 pm
I originally started with 4 Mako Shark mounts, after I noticed they were leaving dents in the hull I added two more mounts for a total of 6. Even with 6 of the Mako Shark mounts to spread the load there were still dents, mostly in the middle and rearmost mounts. I leave my PA on the trailer all the time but it is not strapped down when stored.
I ended up taking the mounts off and now I use 4" black ABS pipe the length of the PA, after a while the dents gradually faded away.
YMMV................
I use a 3/8" security cable through the Mirage drive hole and secure the cable to the trailer with a big lock. You could cable your PA to the reciever hitch if you have one.
