It is currently Wed Aug 12, 2026 1:53 am
PostPosted: Mon Apr 01, 2013 2:31 pm
rudder won't turn as far left as right due to steering knob hitting left side grab rail.
Anyone have a solution?
PostPosted: Mon Apr 01, 2013 3:14 pm
Mine did, too. I opened the rudder access and tightened the line a bit. With the rudder centered, my tiller now points a wee bit right. That gives me equal travel both ways.
You'll see two screws holding the steering lines. Loosen the one on the left (looking forward) and pull that line a quarter inch tighter. You should see the tiller handle tweak a bit to the right. Re-tighten the screw. Done.
Pro Angler-14 owner
PostPosted: Mon Apr 01, 2013 6:28 pm
Thanks! I will give that a try.
