It is currently Wed Aug 12, 2026 1:06 am
PostPosted: Mon Jul 18, 2016 2:02 pm
I love the H-Rail system, and I'm toying with the idea of bolting an H-Rail onto the front of my marine cooler! Want to know if the 21" bolt-on will fit. Can someone tell me the total length of the 21" bolt-on from the outside of base to outside of base?
PostPosted: Mon Jul 18, 2016 9:22 pm
The H-Rail kits, both 9 and 21" come in three sections. The hexagonal tube and the outside mounting brackets or arms. You can easily use a hack saw to cut down the 21" tube on the H-Rail Kit to make it fit perfectly. I mounted the 9" H-Rail on the back of my Coleman 55qt Steel belted cooler, which is about 21.5" wide. Then mounted gear tracks on each side, and a set of YakAttack hog trough brackets on the front.
Here are a couple of pictures. I mainly use the H-Rail to hold my Hobie Tackle Bin behind the cooler, but in easy reach. Sorry everything looks so dirty...I have been fishing a lot and not cleaning enough!
STLKayak
2020 Pro Angler 14 360
St. Louis, Missouri
https://www.facebook.com/profile.php?id=100005695487937
PostPosted: Mon Jul 18, 2016 9:47 pm
Just found a picture that shows the total length out of the bag is 28". But like I said, it would be very easy to trim the tube down to the perfect size you need.
STLKayak
St. Louis, Missouri
