It is currently Tue Aug 11, 2026 10:36 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
 Post subject: Re: Ultimate pa14
PostPosted: Fri May 09, 2014 6:28 am
TexasTarheel wrote:
I second the motion to consider the YakAttack BackPak. It really helps with storage and additional rod-holders. What are you doing for transport and storage?
Converted jet ski trailer I bought for $150. Works really well. And I have a dedicated kayak shed.
http://www.sterlingharbor.com
http://www.facebook.com/sterlingharborkayakfishing
PostPosted: Fri May 09, 2014 6:36 am
Lt.FireDog wrote:
I had a pair of 4" YakAttack GT175 on my first PA12 for a RAM Tube 2008 & Lowrance Mark-4.....kept hitting them when I was either poling or using a SUP while standing.
When I got my latest PA12 this past July, I decided to go with a pair of 12" GT90's installed (w/backing) on the gunnels between the side boards and side handles and replaced the tube with a YakAttack Zooka Tube/RAM Tube Jr....problem solved.
I use a YakAttack BlackPak installed with my "Bombproof Mounting System", I started with 1 single 12" GT90 to hold a VISICarbon Pro and Panfish camera pole for a Swann HD video camera.
I've since switched the single track for a pair of 12" GTSL90's in yellow.
Currently, I use either a 6 or 8' Park-n-Pole in conjunction with a starboard mounted anchor trolley, I was planning on installing another on the port side but may hold off on that as I have a Power-Pole Micro Anchor waiting for pick-up at the factory in Tampa (May 8th :D ).
I used this Harmony SlideTrax Molded Fitting on my trolley in place of the small black nylon cable clamp...does a great job of keeping the lines out of the cockpit.
* Would love to install a SeaDeck or Ocean Grip deck treatment, but I go into a new boat every July. :cry:
I love the track mounted on the gunnel. I was thinking about doing this as well.
PostPosted: Fri May 09, 2014 9:11 am
Cpb1977 wrote:
the one thing i did forget is i will be adding the yak attack blackpak to this list
I love the Blackpak for all the versatility that it adds. Do you do any trolling? I built a DIY rodrack for my PA12 that really gets it done and offers lots of room for storage. I have a crate that I built the rod holder around that will hold all my extra tackle (with a cargo net to cover in case....) or can add a large bucket for live bait, etc.
LtFireDog, what kind of clamp(s) is that holding your "fish measuring device"???
http://www.swfkaa.com/forum/viewtopic.php?f=17&t=865
PostPosted: Fri May 09, 2014 4:50 pm
The measuring device is a Hawg Trough from HOOK1 and the mounts are from YakAttack.
I use the Hawg Trough for freshwater tourneys and have a "Mudfish fish measuring jig" DIY measuring board (w/321Fi$h ruler decal) for saltwater.
http://kayakfishinggear.com/hawgtrough.aspx
http://kayakfishinggear.com/BlackPakAcc ... acket.aspx
http://www.jaxkayakfishing.com/phpBB/topic23479.html
~YakAttack Pro Staff ~ LIVE Watersports Pro Staff ~ RAM Pro Staff ~ Power-Pole Micro Pro Staff ~ Columbia Pro Team~
PostPosted: Sun May 18, 2014 4:38 pm
Cpb1977 wrote:
if you had a "more than enough" budget to sink into an "ultimate pro angler" what would you get??
Larger rudder
Can you provide any details on the "large rudder". I've read a little on the PA14 rudders performance and was curious aside from custom what folks were using and if there is a make/model upgrade from Hobie or 3rd party?
PostPosted: Fri Sep 02, 2016 10:45 pm
What size is that HOOK1 decal Lt.FireDog? Is it the 17.5x3 or the 28x5.5? I'm torn between the two.
2017 PA14 Dune
Lake St. Clair
St. Clair Flatts
St. Clair River and Channels
3x Michigan Master Angler Awards
