It is currently Tue Aug 11, 2026 5:40 pm
 Post subject: drill size.
PostPosted: Mon May 24, 2010 12:49 pm
I am trying to install my anchor trolley and i need to know what is the size of the drill bit to use.
 Post subject: Re: drill size.
PostPosted: Tue May 25, 2010 6:11 am
I made my own trolley, all I can say is to use a drillbit SMALLER than the bolt that will be going through it. I dab silicone seal on after drilling the small hole, then thread/screw the Stainless bolt through the guide hole, dab a bit of silicone inside, then attach the Stainless washer and nut. The Silicone acts as a bit of lubricant and a thread sealer too.
PostPosted: Wed May 26, 2010 8:22 am
I installed mine last night and as far as I can tell, it came out good. The drill bits I used (along with my notes) are at home so I'm not going to try to remember what I used. If I remember, I'll post up when I go home for lunch. It's scary drilling holes in these beautiful boats. :mrgreen:
PostPosted: Fri Jul 02, 2010 7:34 am
:) thanks for the post, i have installed anchor trolley and it works fine......
