It is currently Tue Aug 11, 2026 5:29 pm
PostPosted: Thu Jul 07, 2011 7:35 am
What size pole or pipe fits into the accessory plug on the front of the PA? I think it is for an optional sail, but I'm not sure.
I want to make a camera/camcorder mount and use that accessory plug.
PostPosted: Thu Jul 07, 2011 8:31 am
It's for the sail mast. I takes a 1-inch OD fitting.
I used the same opening on my Outback for the fish finder mount. Get some PVC and go straight up, then fit a 45-degree turn and more straight PVC to get the unit as high and as far back towards you as desirable. Just watch out that you don't locate it so far back that it hits the Mirage Drive.
PostPosted: Thu Jul 07, 2011 8:40 am
Thank you. That is exactly what I needed to know.
PostPosted: Thu Jul 14, 2011 1:29 pm
Bowhunter, have you seen these? Might save you the project time. Reasonable cost too:
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=hobie+camera+mount&_sacat=See-All-Categories
PostPosted: Sat Oct 15, 2011 8:52 pm
Hobie Team Member
Does the 1" OD fit snug?
