It is currently Tue Aug 11, 2026 11:32 pm
PostPosted: Wed Jul 25, 2012 9:17 pm
Any advise on a battery to use for my Minn Kota Endura 30 trolling motor on my PA 12? It needs to be low profile so it can fit in the compartment opening, behind where the tackle management system is located...basically right under the front of the seat. There is a space around 9" wide, 7" deep, and 6.5" high.
PostPosted: Thu Jul 26, 2012 6:42 pm
You can fit a 22-NF (55Ahr) inside the center hatch and slide it back between the scupper tubes and still use your planos as intended, take out the planos and you can put 2 in there and get 110 Ahrs of run time.
Good luck
Steve
PostPosted: Fri Jul 27, 2012 8:01 am
Thanks. Is the battery you're showing from a specific manufacturer, or will any 22-NF (55Ahr) battery work?
PostPosted: Fri Jul 27, 2012 9:50 am
the 22-NF is a size , all of the manufacturers should be the same.
The ones I use are Power Tec
