It is currently Tue Aug 11, 2026 3:23 pm
PostPosted: Wed Dec 14, 2011 8:32 am
I have talked to Aaron at Malone, Customer Service at Austin Kayak, and an installer at AK, they all agree that it is OK to transport my PA like shown in photos.
What do you guys think?
Does this look like it will be OK with no damage to the hull?
http://tinyurl.com/7fd98hb
PostPosted: Wed Dec 14, 2011 12:13 pm
Looks good to me... I haul mine on the rails just flat touching the rails all the way across. i have not has a problem after about 2.5 years. I do not leave on the trailer very long only for hauling to and from the lake.
your set up looks to be much better for the underside of the PA... Good luck.
PostPosted: Wed Dec 14, 2011 2:09 pm
If it gets hot where you live you may end up with dents where each saddle contacts the PA. I use Yakima Mako saddles and there are dents where each saddle contacts my PA. I am going to switch to Hobie's PA cradles.
YMMV
PostPosted: Wed Dec 14, 2011 4:28 pm
I had that system and I switched due to the dents in the kayak. Also had the saddles crack. I went to a bunk system built on pvc.
PostPosted: Wed Dec 14, 2011 4:31 pm
Check out this thread
viewtopic.php?f=78&t=35121
PostPosted: Wed Dec 14, 2011 5:49 pm
That looks like the way to go to me with those PVC bunks.
PostPosted: Tue Jan 10, 2012 9:07 am
We had the same set up with Yakima saddles for our Oasis on the same trailer.
My wife kept warning me that we could cause dents in our Oasis. As usual she was right. :oops: :roll: :o
On the first really hot day coming back from the lake (about a 35 minute drive), we had some really severe dents where the Oasis rested on the saddles. In our driveway, we flipped the Oasis over to rest upside down and most of the indentations came out. It was over 100 degrees, air temp, and egg frying temps on the pavement which reflected the heat up to the Oasis on the saddles.
I bought 4 Yakima round pads for the cross bars, removed the saddles and put the pads on the bars so the Oasis would rest on them upside down. No more indentations and most of the ones from my :oops: original failure have come out.
Hobie has warned us about transporting and storing their yaks right side up. We had one more event that proved they had good advise. We went to another lake where it is hotter and the guys, who patrol the parking lots don't want trailers in most of the lots. So I hooked up my bed extender and we put the Oasis in the bed and on the bed extender rack. 45 minutes later, we had some indentations from the rain slots in the truck bed and across the back rack of the bed extended. On the trip back the Oasis was upside down and the indentations were gone by the time we got home.
YMMV
2009 Oasis
2012 Freedom Hawk Pathfinder
PostPosted: Tue Jan 10, 2012 12:03 pm
Transport yes, store no.
