It is currently Tue Aug 11, 2026 4:22 pm
 Post subject: Wireless Trolling Motor
PostPosted: Thu Jan 19, 2012 1:52 pm
After reading the thread about the using the I-Pilot trolling motor on the PA, I got to wondering...
I have a MotorGuide Wireless 55lb trolling motor with a 48" adjustable shaft mounted to the bow of my 15' aluminum bass boat. It has a wireless foot-peddle AND a hand-held remote that clips to your shirt pocket and allows you to control the motor by just touching buttons with your fingers. It also has a quick-release mounting system so you can remove/install it from the bow deck in just seconds.
I absolutely LOVE that trolling motor. :D
But could it be adapted to work on my PA??
I could easily adjust the shaft length to the proper depth for the PA, but thinking about it, there are still a couple of things that concern me.
1) The unit weighs almost 20lbs and eats a lot of power when it's running, so it requires a full-size marine battery. That would total a lot of extra weight on the bow of the PA.
2) I ordered the H-Bar with my PA because I'm partially disabled on my left-side and I thought the bar would make it easier for me to get in/out of the kayak. I'm thinking the trolling motor on the bow would interfere with laying-down the H-Bar to get it out of the way when I'm sitting down fishing.
Thoughts?
PostPosted: Sat Jan 21, 2012 2:01 am
Mount motor on stern using transom listed in other posts put battery in box behind the seat
cron
