It is currently Tue Aug 11, 2026 4:23 pm
PostPosted: Wed Jan 25, 2012 3:03 pm
When I bought it, I didn't have a PA nor did I have plans to get one. Oh well...minds change. gulp gulp goes the kool-aid. I can still fit 2 yaks and a PA so I guess that will work. It took me a while to get the saddles right but I think this is gonna work out.
Boondoggle!?!
PostPosted: Thu Jan 26, 2012 8:06 am
I ordered the Malone Microsport XT.
My plan is to ...
A. get a hitch installed on my car
B. build the trailer
C. order the PA :mrgreen:
I also have 2 other kayaks...an original "Mirage" and an Outback which I plan on hauling (at times) on J mounts like your picture.
Do you have anymore pics that are larger? That one came out pretty small.
Curious...how did you mount the PA?
I plan on using this 4" drain pipe method with indoor/outdoor carpet glued on the pipes.
viewtopic.php?f=78&t=35121
Fresh: http://www.youtube.com/playlist?list=PLE02E23641B7FE360
Salt: https://www.youtube.com/playlist?list=PLeb5zOGDfoKlEPsMK5GBUOge_Qz5u2koH
PostPosted: Thu Jan 26, 2012 8:47 am
this is pretty much my plan although I keep looking for a jet ski trailer or similar to save money on that.
PostPosted: Thu Jan 26, 2012 6:06 pm
My plan is to ...
I called Malone and they recomended the Saddle Up Pros.
http://maloneautoracks.com/saddle-up-pro.php
I made that other image larger also. Here are some of the Saddle Up Pros in action. I use just for transporting as I do no think it will be a good idea to leave them strapped up like this for it might bend the hull.
I actually use the cross bars to support the saddle up pros so they can't move around and have them more on the side like a book end.
It is working fine right now.
PostPosted: Thu Jan 26, 2012 6:12 pm
The Malone specs say for 80-90 lb. kayaks. Concerned?
PostPosted: Thu Jan 26, 2012 6:16 pm
You may want to put some foam blocks under the hull on each load bar between the saddles in case the saddles fail. I use 6 Mako saddles under my PA and two of the saddles have collapsed.
