It is currently Wed Aug 12, 2026 1:29 am
 Post subject: Fiberglass paddles
PostPosted: Sun Feb 19, 2012 7:48 am
I searched back over a year in these discussions only to find very little on paddles for the Pro Angler. (I haven't received my ordered PA yet, so this is the voice of inexperience right now). Should I want to paddle it ( just to get away from rocks, back up, etc. and maybe occasionally paddle across open stretches of lake) am I better off with a long wooden canoe paddle or should I be keeping an eye out for a 240 cm plus fiberglass kayak paddle? I am 6'1" and hubby is 6'6".
Anyone ever paddle around in their PA?
Arctic Mermaid
Life is just one big Exploration. Enjoy!
 Post subject: Re: Fiberglass paddles
PostPosted: Sun Feb 19, 2012 7:54 am
I am 6'3" and it has been my experience that the PA does not paddle well for me, it is so wide and I have too much gear set up on my side rails (Scotty rod holders and fish finder). I will paddle to get away from the shore so I can put the drive in and that is about it. I did forget the drive unit at home once and I did have to paddle around on a small 7 acre lake, it was not the most fun trip although I did manage to make the day a productive fishing day.
I find myself thinking ahead to avoid situations where I would need to back up or get around obstacles, I have never had to paddle to get out of trouble. The stock Hobie paddle that comes with the PA is set up so you can either is it as a one piece two bladed paddle or you can use half of it with a "T" in the end like a canoe paddle. My 09 PA did not come with a functional paddle holder (it does have a clip behind the seat but it is not secure or functional) so I added clips to the left side side rail to secure the paddle.
PostPosted: Sun Feb 19, 2012 7:57 am
I can see from a lot of the posts, beside yours, that the side rails can get pretty loaded up ( so I can see where that would be a problem) . I will probably go slow with regards to buying and installing accessories.
When you do paddle it, what do you use?
thanks for your reply
Arctic Mermaid
PostPosted: Sun Feb 19, 2012 8:01 am
I use the stock Hobie paddle connected together so that it is a normal two bladed paddle.
PostPosted: Sun Feb 19, 2012 8:06 am
Great thanks!
Ah! I see your added info. I didn't think the PA came with a paddle. Excellent. So yes, I will try that out first.
Arctic Mermaid
PostPosted: Sun Feb 19, 2012 8:41 am
For my Freedom Hawk 12, my grown kids used the following formula.
It is a wide yak, and they went with an adjustable paddle and one that feathers. It adjusts from 210 to 240 and has several feathering choices. It is a two piece paddle for convenience of transporting and storing. These paddles are not cheap, but they work in wide yaks and being adjustable should work for both of you.
Choosing a Paddle For Kayak Fishing
Submitted by kayakfishingstuff on Tue, 12/30/2008 - 11:35
Tips and Tricks
Original Author:
Kayak Fishing Stuff - Originally submitted by Bob Smitty
What exactly makes a good paddle for kayak fishing? For most of us the paddle is a mere after thought when compared to the decision process involved in choosing a kayak. While choosing a paddle isn't as mind boggling you should put a little thought into deciding what type of paddle you will purchase. After all, in a kayak you and your paddle are the motor.
The Internet and paddling books are full elaborate formulas to figure what is the exact paddle length a person should use based on the height and kayak width. Most sit on tops between 28" and 34" will do just find with the standard 230 centimeter paddle. A few factors could change that, a 230 works well for most people who kayak fish because kayak fisherman usually use a more relaxed paddle touring stroke (arms rarely going above shoulder height, more off a horizontal stroke) but sometimes we might want a power stroke (paddle in a vertical position) used more whitewater paddlers and speed, for instance, if you were sprinting after some crashing fish and needed to generate some short burst of speed. If you were using a wider kayak or if you are a shorter paddler you might consider a going up to 240 centimeters to give you that same versatile range of paddle strokes. If you are a littler more evolved in your paddling stroke you could look to go shorter but you will be more limited to a vertical stroke that takes more energy to sustain. Part of the new paddle technology is the adjustable shaft - this could be useful as the paddler learns what stroke he/she is the most comfortable with. Usually, the adjustable range is 15 centimeters.
When choosing a blade shape we feel that same approach of allowing for the most versatility for kayak fishing is the way to go. A blade that combines the longer narrower touring style blade with the power of the big surface whitewater and surf style blade is what you want here. Paddle companies usually refer to these as " All Purpose" or "Recreational" style blades.
Choosing a shaft and blade material is simply a matter of what you want to pay for lighter weight. A lower end paddle usually is made up of aluminum shaft and plastic blades, as you move up to the higher end paddles you find materials liker fiberglass and carbon fiber composites. Is it worth it to pay for lighter material when the heavy paddle can also get the job done? It is the same decisions we might face when buying a fishing rod or reel, sure we can catch fish with the cheaper rod and reel but after using a higher quality tackle most of us would never go back. The best bang for the buck might be in the difference of the $50 and $150 paddle, the returns you get for the difference of the $200 and $300 paddle might not be appreciated as much.
Some other considerations when choosing a paddle, a 2-piece paddle will allow you to transport it much easier than a one piece. Newer paddlers might not think it is important to get a paddle that can be feathered. (Feathering refers to the blade plane configuration of a kayak paddle. When the two blades of a paddle are in the same plane as indicated by being able to lay it with both blades flat on the floor at the same time, it is unfeathered, or no-feather or zero feather. A feathered paddle is indicated when the blades are at any angle away from the same plane, and only one blade will lay flat on the floor at a time), but in time, using the feathered paddle stroke will come natural and be much more efficient. Most of us are fisherman first and paddlers second but it is a good idea to understand the basics of paddling - this will help in not only choosing a paddle but also in being more efficient on the water.
You can view all of the paddles available at Kayak Fishing Stuff by clicking here. Also, if you'd like someone to help you choose the correct paddle feel free to call us at the shop 866-925-4537 or email us.
2009 Oasis
2012 Freedom Hawk Pathfinder
PostPosted: Sun Feb 19, 2012 10:19 am
hey Grampa Spey; thanks so much. It's a very informative article.
Arctic Mermaid
