It is currently Tue Aug 11, 2026 7:49 pm
 Post subject: Loading a PA on roof
PostPosted: Wed Feb 22, 2012 9:34 pm
Ok here's the scenerio. Girl just got a mini van Nissan quest with factory rails. If I throw Yakima rail grabs on top will it support a pa? The Yakima site says they can hold 165 lbs. I am unsure of the quest rail limit. I normally load it in my truck but she got the van for long trips just hoping to be able to bring the yak along to go fishing.
 Post subject: Re: Loading a PA on roof
PostPosted: Wed Feb 22, 2012 9:42 pm
Should be fine. You might want to check the capacity of the roof rack, it should be in the owners manual if it's not on a sticker directly on the rack. The bigger problem is lifting a Pro Angler that high! Also, handling of the Nissan will be affected with that much weight that high up.
PostPosted: Wed Feb 22, 2012 10:51 pm
The factory crossbars are 125 it does not have those so I got the yakimas which have a higher capacity. I will check the Manual see if they list rail capacity in there.
Thanks for the reply
