It is currently Tue Aug 11, 2026 7:59 pm
PostPosted: Sun Apr 29, 2012 7:15 pm
I want to put bunk carpeting on my PVC pipes which I use for my PA. Any advise as to what glue and how to keep the padding in place until the glue dries? Many thanks for any help!!
PostPosted: Sun Apr 29, 2012 9:16 pm
Don't know where I read it from, but I believe someone said, gorilla glue.
2011 HPA
2006 Wildy Ride 135
2019 Hobie Compass
2020 Hobie Outback
PostPosted: Mon Apr 30, 2012 8:53 am
Iceyak,
I design and make custom furniture and quite often find that I'm having to glue up mating surfaces that are round, tapered or just don't lend themselves to standard clamping procedures. One trick of the trade is to use sand bags. It will give you the weight needed as well as conform to the unusual shapes being glued together.
As for the glue... I haven't had any experience with gorilla but you'll definitely want to avoid something that is brittle once it has cured. You might want to consider rubber cement as it will flex along with the PVC tubing. It is best applied to both surfaces and waiting until they are tacky, then mating them. DO read the labels to be sure they can be exposed to water. One thing about using this method... get it right the first time or you may have to start over.
I hope this info is helpful and good luck!
GR8 Laker
PostPosted: Tue May 08, 2012 9:07 am
Thanks for the info Gr8 Laker.
Anyone out there actually put bunk padding on their PVC? If so please let me k ow what glue you utilized!!
PostPosted: Tue May 08, 2012 1:14 pm
Is there a benefit to placing carpet on the pvc? Personally, I kinda like how easy it is to slide the PA on it...especially when it is wet. Never saw a need for the rug.
2011 HPA
2006 Wildy Ride 135
2019 Hobie Compass
2020 Hobie Outback
PostPosted: Tue May 08, 2012 6:12 pm
I feel like it still scratches the bottom a little. Maybe it's just my imagination or I just need another project. :lol:
PostPosted: Tue May 08, 2012 9:28 pm
Fresh: http://www.youtube.com/playlist?list=PLE02E23641B7FE360
Salt: https://www.youtube.com/playlist?list=PLeb5zOGDfoKlEPsMK5GBUOge_Qz5u2koH
