It is currently Wed Aug 12, 2026 2:55 am
 Post subject: Paddle storage?
PostPosted: Wed Apr 18, 2012 4:26 pm
Do you guys store your Hobie paddle inside your boat? I didn't spend much time trying to get it in there but it doesn't look like it will fit in the front hatch.
 Post subject: Re: Paddle storage?
PostPosted: Wed Apr 18, 2012 7:35 pm
I generally use just half the paddle with the T-handle. I store the other half in the hull. I slip it in though the front hatch and use a small bungee loop connected to a plastic ball to hold it in place along side the bottom rod tube.
PostPosted: Sun Apr 22, 2012 5:40 am
I use the full paddle and it is secured to clips that are attached to one of the side rails, I found the clips at West Marine. out of the way but easily accessed when needed. Scotty makes a cool paddle clip:
PostPosted: Sun Apr 22, 2012 11:15 am
It looks like Hobie actually connected this paddle mount directly to the paddle shaft as opposed to mounting it to the rail on the PA12. Did I see this right in the video on the website? I like this idea as it seems to make placement of the paddle very flexible.
PostPosted: Sun Apr 22, 2012 11:21 am
It will fit in, under the front hatch liner. When you place it inside there are two foam floatation pieces that have to be pushed rearward a few inches, but it will store inside.
The paddle has been pretty useless for me except as a possibility for emergency if the drive fails. I use a push pole to push off of banks or to push along in very shallow water.
I think the Native paddle mount on the side rail would be the best if you feel you need the paddle.
PostPosted: Sun Apr 22, 2012 11:49 am
I would much rather push pole in the shallows which is what I always did in my pirogues anyway. I just used a paddle though. I think with the PA I'd like to get an actual push pole though and keep the paddle in the hull for emergencies. Now to try and find a decent 14' or so push pole that won't cost me $300!!!
