It is currently Wed Aug 12, 2026 2:55 am
 Post subject: Seat Mount Question
PostPosted: Fri Jun 08, 2012 1:51 pm
Top view and notice the yellow arrows.
In the picture the upper mount (port side) is not attached the same as the bottom mount (starboard side). In fact it is loose on the round bar with just the end caps keeping it in place. The front port rivet is in fact only on the black pipe. Hard to tell from that angle.
Is this "play" normal?
I am questioning if this is a defect or not.
Fresh: http://www.youtube.com/playlist?list=PLE02E23641B7FE360
Salt: https://www.youtube.com/playlist?list=PLeb5zOGDfoKlEPsMK5GBUOge_Qz5u2koH
 Post subject: Re: Seat Mount Question
PostPosted: Fri Jun 08, 2012 4:01 pm
Yes, that's normal.
Cheers,
Adam
http://www.yakfisher.net
PostPosted: Fri Jun 08, 2012 8:23 pm
Bubbleboy wrote:
Yes, that's normal.
Thanks.
It seemed odd to me but my hunch would be that they needed to keep one side slightly movable in order to line it up.
Just a guess though.
PostPosted: Sat Jun 09, 2012 3:16 pm
SHRED56 wrote:
Bubbleboy wrote:
Yes, that's normal.
Thanks.
Yep, that's exactly the reason. Leaving a little play allows for getting the holes to line up with the retainer bolts. I find the alignment can change some with temperature. While you have the seat apart, you should think about adding a seat slider! (see other threads about making this modification)
PostPosted: Sat Jun 09, 2012 3:28 pm
...or a simple riser. See MY thread on that.
Pro Angler-14 owner
PostPosted: Sat Jun 09, 2012 3:34 pm
TDK wrote:
SHRED56 wrote:
Bubbleboy wrote:
Yes, that's normal.
Thanks.
Thanks...I removed the seat for the first time and noticed that side was loose that is why I asked.
