It is currently Wed Aug 12, 2026 6:38 am
PostPosted: Tue Sep 11, 2012 2:02 pm
Trying to put bunk carpeting on my pvc. What can I use that will stay on the pvc?
PostPosted: Tue Sep 11, 2012 2:38 pm
Contact cement
Marc...
PostPosted: Tue Sep 11, 2012 3:06 pm
Thank you sir!
PostPosted: Tue Sep 11, 2012 4:51 pm
NP just make sure to read the instructions prior. It's not hard to use, but also not forgiving.
Marc...
PostPosted: Tue Sep 11, 2012 5:21 pm
Any suggestions what to use to hold carpet on while cement is drying?
PostPosted: Tue Sep 11, 2012 5:43 pm
I'm thinking duct tape should hold the carpet till it dries. Also, sounds like this may be a two person job :roll:
Will be watching this thread as I am planning the same project this weekend :!: :!:
PostPosted: Tue Sep 11, 2012 5:50 pm
I'm 50 years old and just had a tonsillectomy. Time off to heal but gotta get things done as well. Priorities. :mrgreen:
PostPosted: Tue Sep 11, 2012 7:42 pm
Nothing . Its contact cement, as soon as it makes contact its cemented. Apply cement to carpet and pvc, let it tack up then lay the carpet down.
PostPosted: Tue Sep 11, 2012 7:48 pm
I have had one of my tonsils removed it was more painful than when i tore my achilles. I'm not going backe to vet the other one removed
PostPosted: Wed Sep 12, 2012 9:03 am
Success! Sanded down pvc slightly, wiped it clean, applied contact cement. Cut my bunk padding, applied contact cement and let all set 15 minutes. Once time passed, layed carpet on pvc, pressed firmly onto pvc and that's it!!! Very easy to do BUT many thanks to "56kz2slow" for answering the main question for this task!!!
PostPosted: Sat Sep 15, 2012 8:45 am
I scuffed mine with 36grit cleaned with alcohol, and then applied regular carpet glue. It's been holding well for about a year now.
http://www.kayakbassfishing.com Pro Staff
http://www.yakattack.us Pro Staff
http://www.mariner-sails.com
http://www.TFOrods.com
