It is currently Fri Jun 26, 2026 9:03 am
 Post subject: Pro Angler leaking.
PostPosted: Mon May 27, 2013 6:19 pm
I have a new from the dealer (purchased in march) pa14,I noticed that when I have taken it out, it takes on quite a bit of water, I have checked the hull and cannot find any holes /cracks. It has been garage kept, and on a custom rack for storage. I have not dropped or hit anything that could have dmged it.
Is this a known issue?
Any ideas what /where to check
Thnx
 Post subject: Re: Pro Angler leaking.
PostPosted: Mon May 27, 2013 6:24 pm
Check your drain plugs. I would put some water in it seal the plugs, then tip it up and see if any water runs out.
PostPosted: Tue May 28, 2013 10:50 am
A friend of mine had a PA12 which leaked at the point where the re-enforcments within the rear scuppers end near the top of the scupper holes.
PostPosted: Tue May 28, 2013 2:07 pm
The dealer should be able to help you with this. There is a FAQ on how to locate a leak that can easily be done at home if needed: http://www.hobiecat.com/forums/viewtopic.php?f=21&t=12575
PostPosted: Tue May 28, 2013 10:19 pm
Unfortunately the dealer is located in Georgia, and I am back home in Texas, now that I am out of the Army.
PostPosted: Wed May 29, 2013 8:42 am
Any Hobie dealer should be able to help you. Especially since you have relocated.
PostPosted: Sat Jun 01, 2013 6:36 pm
Be sure and check the top of your cockpit..........I started taking on lots of water and couldn't find the leak until I discovered a crack in the top of my cockpit right under the rudder control:
Hobie took care of my issue.
