It is currently Wed Aug 12, 2026 3:15 am
PostPosted: Sun Aug 20, 2017 1:30 pm
After a year and a half of very hard use, I had the steering line break on my 2016 PA14. Anyone know what the part numbers are for the replacement line? I figure I might as well replace all three runs at the same time. Might also work on fixing the skeg issue with it cutting into the hull...but that can probably wait, since I have not used it for a year...that is until today. Steering this pig with a paddle is tough! Having the skeg down and rudder up helped a ton.
STLKayak
2020 Pro Angler 14 360
St. Louis, Missouri
https://www.facebook.com/profile.php?id=100005695487937
PostPosted: Sun Aug 20, 2017 9:07 pm
For the PA-12 and PA-14, post 2013, the Hobie line replacement kit is P/N 80019011....has 30' of spectra line and 2 guide tubes.....about $45.
I doubt you need to replace the BOA line since it only adds/slacks the rudder line tension between the "rudder tillers".
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Mon Aug 21, 2017 7:19 pm
Thanks Doc! Ordering tomorrow morning!
STLKayak
St. Louis, Missouri
