It is currently Wed Aug 12, 2026 6:24 am
 Post subject: Another DIY PVC Cart
PostPosted: Tue Jun 25, 2013 11:27 pm
Hi everyone. First, I want to thank the folks who posted their DYI cart designs, which inspired me to do the same. I too was thinking about getting a Pro Angler but I was surprised of the price of the Hobie cart. Buying four tires for my car was cheaper. I went ahead and purchase the 3/4" axle from wheeleez since it fits inside 3/4" PVC pipe without a need for a bushing or reducer. At 28.5" in length, I was going to cut the length but the current design (for 26 cm Foam "Tuff Tire" Wheels) will allow me to still reuse the axle if ever I wanted 30 cm wheels later. Thank goodness PVC is fairly cheap.
I made the mistake of buying Hobie's Post Collar Clamp which is too small for 3/4" PVC. I'm still working on a fix but feel free to post any suggestions. Any input will be greatly appreciated for this work in progress.
Thnx in advance
 Post subject: Re: Another DIY PVC Cart
PostPosted: Wed Jun 26, 2013 5:41 pm
Figure out exactly where you want the PA to sit on that cart so it clears your wheels. Then get two cross tees for the 3/4 pvc pipe. Cut the PVC pipe to accept the cross tees with the cross pointing fore and aft on each side. Now when you put the pipe up into the scuppers the cross tees will catch in the hollows and stop the downward movement of the PA without putting a cross bar in contact with the rounded bottom which will dent it.
Hobie PA14 with a mod or two
PostPosted: Wed Jun 26, 2013 6:23 pm
Saw somewhere that someone used tennis balls for the hull protectors on the uprights of the cart.
PostPosted: Thu Jun 27, 2013 6:34 am
That might have been me. I use them above the hard collars on the Hobie Heavy Duty cart. The Hobie collars are all the way down and I have the drilled out tennis balls slid down above the collars. Provides a great cushion against the scupper hole area and still allows the ends to protrude through at the top for the retainer pin.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Thu Jun 27, 2013 6:58 am
Is you r PA a 12 or 14???
"Many men go fishing all of their lives without knowing that it is not fish they are after." ~Henry David Thoreau
2013 Hobie Pro Angler 14
PostPosted: Thu Jun 27, 2013 5:40 pm
I have a PA14.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
