It is currently Wed Aug 12, 2026 1:50 pm
 Post subject: Rudder issue
PostPosted: Tue Jul 09, 2013 12:38 am
So my rudder is rubbing at the midway point on the keel of my PA. Clearly needs adjusting just not sure what to adjust. Anyone know what to do?
 Post subject: Re: Rudder issue
PostPosted: Tue Jul 09, 2013 3:51 pm
Post a picture or describe the problem with more detail. Might help get you answers.
PostPosted: Tue Jul 09, 2013 6:25 pm
Pic isnt gonna show much, a PA has a keel that ends in front of the the rudder. When the rudder crosses midship the forward part of the rudder is rubbing on the keel and i can feel it in the handle and it takes effort to get it to crossover. It needs some type of adjusting to move the rudder aft.
PostPosted: Tue Jul 09, 2013 8:59 pm
Have you contacted your hobie healer?
PostPosted: Wed Jul 10, 2013 9:45 pm
yes he said to light some incense and place crystals around the rudder while repeating the mantra "hobie love"
PostPosted: Wed Jul 10, 2013 10:28 pm
Well there ya go...easy as that.
PostPosted: Thu Jul 11, 2013 6:16 pm
I just looked at mine (pa12). I have 2 to 3" of clearance between the front of the rudder and any part of the boat. Picture may help if you can see where it is rubbing. Pop the steering cover I bet the problem is there.
Jim
PostPosted: Fri Jul 12, 2013 11:22 pm
it worked itself out
PostPosted: Sat Jul 13, 2013 5:40 pm
So it wasn't broke then huh?
PostPosted: Sat Jul 13, 2013 5:47 pm
I think I unloaded it out of my truck bed into the sand and it got jammed forward so once in the water it was hard to pass the rudder but midship but the nexttime I went out in the ocean it was fine
