It is currently Wed Aug 12, 2026 12:58 pm
PostPosted: Wed Aug 14, 2013 8:57 am
It's been a year and my kayak trailer has been through a few configurations. I started with a Harbor Freight 4'x8' trailer w/13" wheels. Originally I used carpeted bunks which came from an old trailer which I didn't like, the kayak slid around when loading/unloading so I changed them to PVC which I learned about on this site.
My next issue was the short trailer was difficult to back up, it changed directions much quicker than my 21' boat trailer, so I wanted to make it longer. Another reason for extending it - I didn't like so much kayak hanging off the rear. Harbor Freight was having a sale so I purchased another trailer kit for parts. Actually added a 4'x4' section to the front of the trailer. That connection between the old and new section proved weak with just the bolts, so I welded the two together and kept the old tow bar on to support the new section. This is what I ended up with as a single kayak trailer.
This shows the added 4'x4' section and the original tow bar with some uni-strut support.
I was happy with that for hauling my own PA-14, but I travel and have other friends with kayaks so I thought about modifications to haul multiple kayaks so we all didn't have to drive separate vehicles. Most of my friends car top and don't have trailers. First thought was to put on a second tier and use J-bars on the sides to haul NON-PA (read normal) kayaks. So I did this:
It worked, everything traveled well the first trip, but is proved a bad idea when it came to unloading the top PA at the ramp. I found I had to stand thigh deep (waist deep at high tide) and lift it head high to load/unload it at the ramp, OR load the lower kayak then pull the trailer forward and carry the second PA up the ramp and lift it up. It was a lot of trouble/effort and needed changed.
The latest configuration will carry two kayaks - I can carry two more on J-bars on the roof of my Durango, if need be so I thing a 2 kayak trailer is the way it will stay.
But I only transport my own kayak most of the time and I didn't want to have the wide 2-kayak a permanent thing, I wanted to make it convertible AND a conversion I could install/remove myself and not take a lot of storage space. The following pictures show the conversion. It takes about 15 minutes (by myself) to install or remove the 2 kayak platform.
Single configuration:
The base of the platform uses 3 cross members. I used 2"x6" treated lumber for the middle and rear
as they support the weight of the kayak. The front one is a 2"x4".
The cross members fit into the stake pockets that are included with the trailer. I added a second piece of 2"x4" that sits on the frame, for a little bit more support and stability.
I bolted U-bolts through the cross members to attach the PVC rail sections. These act as studs, I don't have to deal with them each time I do and install/remove, they remain in place so I just have to bolt down the rail sections to the "studs". This is the underside and I used 3 washers so the studs didn't stick up so high and hit the kayak hull.
All 3 cross members in place, rest on the PVC rails of the single configuration for support and you can see the "studs". I doubled up on the rear U-bolts as that is the biggest stress point when loading/unloading the kayaks and I wanted the rails secure.
The pair of PVC rails are connected by sections of uni-strut that maintains the spacing and the "studs" slip through the uni-strut and a washer, lock washer & nut makes the connection.
Loading/unloading the kayaks isn't any more difficult now than with the single configuration. They sit about 6" higher, but still can be backed right to the water and slid on off easily. You may note the different color in the PVC - I hate Home Depot, every time I go to get something they don't have it. I prefer the grey electric conduit as it is UV resistant. That's right HD didn't have it when I went so had to settle for the white PVC plumbing pipe. No biggie it should last many years.
I like the uni-strut, made a bracket to hold my spare tire underneath the trailer.
I painted the trailer with Rustoleum Bed Liner, it's ok but you really should sand and primer before painting - I'didn't, I just washed and roughed up the exisiting paint with a pad and the new paint has chipped off in a few spots. Lesson learned.
With the 5 sections, storage does not take up a lot of room and each is easily handled by myself.
2012 PA-14 Dune; 2013 PA-14 Yellow.
PostPosted: Wed Aug 14, 2013 9:24 am
Bruce
Great info on the trailer but I see the same pic.
Can you load the other pics so I can get some ideas lol.
PostPosted: Wed Aug 14, 2013 9:48 am
I'm seeing all different pictures, WTF did I do wrong. Let me try and fix it. I have to ask if that fixed it, because I saw all the different pictures the first time.
PostPosted: Wed Aug 14, 2013 10:38 am
I can't see them thru the app but I see them on the website.
PostPosted: Wed Aug 14, 2013 12:22 pm
Sweet setup, all the pics look fine from here and thanks for sharing . Nice of you to come up with a way to transport friends' yaks too... I betcha they like traveling with you now, as opposed to loading yaks onto the roofs of their cars :)
PostPosted: Tue Aug 20, 2013 11:59 am
Would it have been easier to just add a pipe to both sides of the trailer so that you could either use the two inboard pipes if you have one PA or load two PA's using the outboard pipes, or is your trailer not wide enough? (does this even make sense?)
PostPosted: Tue Aug 20, 2013 1:22 pm
Could not do that, I had to add the second tier cross members to clear the fenders. The single configuration has the kayak sit below and between the fenders. I wanted a removable configuration for the dual transport, as 90% of the time I only transport my one PA-14 and the dual kayak set-up is a much tighter fit in my garage.
PostPosted: Sat Sep 07, 2013 12:50 am
I had the same problem. I have a sport trailer with cross bars on 34" centers. It came with 60" cross bars and to carry my buddy's yak I ordered and installed 80" cross bars. Normally I carry my PA 12 sitting on 2 inch PVC pipes 5 ' long, centered on the trailer. The pipes are not mounted to the trailer. To put the pipes under the PA, I lift each side of the PA a couple inches and roll the pipe into place, very easy to do. To carry my buddy's yak, I wiggle/slide my PA to one side. The pipes stay in place in the scupper hole tracks since I do not lift it. Takes about 30 seconds. Also the pipes stay in place with the straps tightened during travel. At launch I put the pipes in my SUV. Very simple and convenient for me.
2013 PA 12 Dune
2014 Outback Olive
PostPosted: Sat Sep 07, 2013 12:55 pm
Congrats - I like the removable setup! :D
PostPosted: Sat Sep 14, 2013 6:22 pm
Very nice work.
Hobie Pro Angler
