It is currently Wed Aug 12, 2026 10:48 am
 Post subject: Garmin for PA 12
PostPosted: Mon Feb 17, 2014 1:51 pm
Is anyone running with a Garmin 740S? I just picked up my PA 12 and I was going to move the Garmin from the boat I am selling to the PA. I know it's probably overkill but it's a nice unit. Thanks.
 Post subject: Re: Garmin for PA 12
PostPosted: Tue Feb 18, 2014 9:59 am
I was going to install a echo 150 and was told by the people where I got my PA14 the Lowrance ready system will need modification to it if it can be done at all so I returned it and got x4 pro
2014 Pro Angler 14 Dune
2013 Outback Papaya
Military Police, USAR SFC
Broward County Florida
PostPosted: Tue Feb 18, 2014 11:45 am
I recently upgraded my Garmin 300 Echos to 301dv Echos. Won't use anything else. These are just too good, and allow you to switch back and forth between standard view and DV view. Everything about them is brighter, clearer, more sensitive than my Lowrance and Eagle units.
PostPosted: Tue Feb 18, 2014 1:31 pm
How did you mount the transducer?
PostPosted: Tue Feb 18, 2014 2:24 pm
I had planned to do an outside the hull mount, as these things aren't supposed to read well if you shoot thru hull. However, I mounted it inside and tested it and it works exceptionally well. The tech at Garmin said that it may be that a thin plastic kayak hull isn't the impediment that a thicker, cored glass hull would be. For now, I'm sticking with the shoot thru hull.
PostPosted: Tue Feb 18, 2014 3:38 pm
Thanks for the info. I was looking at that Ram Rail Mount also.
