It is currently Wed Aug 12, 2026 10:48 am
PostPosted: Wed Feb 19, 2014 12:27 pm
Hey everyone I am looking for pics and opinions on the best way to mount a side scan transducer on a PA12. I am really leaning toward the HDS 7 bundle and looking for opinions on mounting the larger transducer. I know I can mount the transducer on a side arm but looking for other way of doing so to have a cleaner look.
I was thinking about possibly mounting on the rear grab handle centerline with boat. Any opinions on this as far a disturbance from rudder or cavitation? I would modify a RAM mount and use this for mounting so I can swing up and away when needed. Thanks everyone!
PostPosted: Wed Feb 19, 2014 5:33 pm
I can't help you with the Lowrance fittings, but I've mounted my HB sidescan transducer where the Lowrance Ready mounts is, underneath the hull. It's permanently mounted there.
Here are some pics of the mount I made to give you some ideas. The material is 3mm aluminium plate and 2mm x 40x40mm aluminium angle. The protective blob of material in front of the transducer is epoxy resin putty.
This one shows the setup from above.
A side view of the bracket
Now fitted to the hull in place of the plastic hull mount supplied by Hobie.
The view from the rear of the hull with the yak resting on flat ground.
Cheers,
Graeme
PostPosted: Fri Feb 21, 2014 7:12 pm
There's no need to make the plate, do the same thing your doing but to the plastic cover. Slightly recess the transducer into the cover from the outside, basically insert the cable and mounting area by cutting the cover than build it up with marine goop both from the outside and inside. Make sure that the transducer beam clears the hull on both sides. The transducer can take a beating so don't worry about damaging it. There is a photo in this forum of what your looking for.
tight lines
Steve
PostPosted: Sat Feb 22, 2014 1:31 am
I'm sure the transducer can take a beating. It's the original plate (after being cut) that I thought would cop a hiding.
I also wanted a protective blob in front of the transducer to prevent it being knocked up and out of alignment and to prevent weed catching it. Epoxy won't stick to PE, but there may have been something else I could have used.
Cheers,
Graeme
PostPosted: Sat Feb 22, 2014 9:07 am
http://bassyaks.com/wp-content/uploads/2014/02/20140222_132708-800x600.jpg
Use marine goop
layer it on and it will never move
PostPosted: Sat Feb 22, 2014 9:31 pm
SteveK wrote:
This looks sweet. Do you have any pictures of the plastic plate before you gooped the transducer
PostPosted: Sun Feb 23, 2014 3:47 am
look at kdfu.com.au rigged section of posts, revo 13 with retractible transducer for humm 598 sidescan,
has photo.s and parts cost less than $15 , no extra holes or mods to kayak, other than cutting base plate,
would attach photo,s but unsure how to on this forum.
cheers
PostPosted: Sun Feb 23, 2014 3:50 am
SteveK wrote:
That does indeed look very good.
(Marine goop is not available here in Australia, as far as I know. Lots of good things you have aren't available here … :( )
Cheers,
Graeme
PostPosted: Sun Feb 23, 2014 2:43 pm
Cheers,
Graeme
have a look at this, retractible humm side scan transducer 598
http://www.kfdu.com.au/forum/viewtopic.php?f=12&t=37230
cheers
PostPosted: Mon Feb 24, 2014 4:34 pm
cheers
Nice, but it won't work on a PA14 because the hull design does not have a place to lift the transducer pole through. The scupper from the transducer well for the cable is placed behind and beneath the Vantage seat and is not open at the top of the hull. (The cable comes through a hole on a vertical part of the hull.)
Cheers,
Graeme
PostPosted: Wed Mar 12, 2014 11:45 am
I really like the setup, but it requires a machine shop. This is where most of us will fail. A year ago, I just cut out the bottom of the lowrance mount and have had no issues since. Just providing an alternative...
viewtopic.php?f=78&t=46839
