It is currently Wed Aug 12, 2026 12:32 pm
 Post subject: PA rudder control
PostPosted: Fri Aug 01, 2014 10:55 pm
Can anyone tell me if the rudder control handle on a PA can be turned around so that the long end is facing the rear of the boat? I rented one recently and spent some time paddling it. My paddle hung up under the handle several times and just wanted to see if thats possible.
 Post subject: Re: PA rudder control
PostPosted: Sat Aug 02, 2014 3:18 pm
On my 2013 PA-14, the answer is no because the handle "nests" into the plastic bracket that also holds the elevated, horizontal aluminum tube.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Sun Aug 03, 2014 6:54 am
Thanks for looking.
PostPosted: Mon Aug 04, 2014 2:34 pm
If you buy or rent a PA 14, ask for the longer paddle. The PA 14 is very wide and a longer paddle will help get a better reach to each side without have to rock you body from side to side for the reach. Just my 2 Cents worth. Good Luck
PostPosted: Mon Aug 04, 2014 3:11 pm
Will definitely do that.
