It is currently Wed Aug 12, 2026 2:58 pm
PostPosted: Wed Sep 03, 2014 9:34 am
After doing a lot of reading and wanting to properly store the 14' PA, I decided to build the kayak cart I saw on here with a few diffrences.
I didn't want the cart as wide so I built it to 98"L X 38"W. for the height I used my truck bed loading height.
With the smaller width the sides of the PA will hit the wood. I used a block underneath the PVC to raise the kayak height. I also carpeted the rails to prevent scratching and slide easier.
I mounted the PVC to the cart by using strips of carpet as strapping material to let the PVC flex and adjust to the contour of the PA.
Added a few more supports and a shelf on the bottom with castors. Total project cost $75.00
PostPosted: Wed Sep 03, 2014 11:14 am
Really like that, any chance you can post pics without the kayak?
PostPosted: Wed Sep 03, 2014 1:39 pm
I'll be salmon fishing the next week w/out the kayak but next time I load the yak up i'll take some pics of the rack.
PostPosted: Wed Sep 03, 2014 2:23 pm
Looks great. Do you think an Outback would fit underneath?
2014 Pro Angler 12'
2014 Outback
PostPosted: Wed Sep 03, 2014 3:15 pm
Revell, I build a similar cart and yes the outback did fit below. I currently only have an outback, so I down sized the cart.
If anyone goes to build one of these don't skimp on size on the casters. I used all four that swivel but only two lock in place. Off hand I think I used 4" casters, hard wheels. I did get these from the home center.
PostPosted: Thu Sep 04, 2014 8:53 pm
Hobie Team Member
I did something similar but I used a picnic table I bought at Lowe's. Slapped some locking wheels on it and viola… double duty PA cart that is very close to being the same height as my tailgate.
Proud owner of a fleet of Hobie Revolutions! Five in the household and five Revo's on the water chasing redfish, trout & flounder in the shallow marshes of Loozyanna.
PostPosted: Mon Sep 08, 2014 9:14 am
Sure if you build it to different dimensions (width) it would! The revo fits, but I use the bottom shelf to store all the kayak gear...
Here are pics without the PA: The carpet is pulling up a little I'll nedd to add a little more spray glue.
PostPosted: Mon Sep 08, 2014 9:30 am
I used the ones from Lowes made by kobalt they were $19.99 for the set of 4, all 4 swivell and 2 lock.
PostPosted: Tue Sep 09, 2014 12:42 pm
Thank you, was that 3 inch pipe?
PostPosted: Tue Sep 09, 2014 1:24 pm
I used 2 1/2 conduit instead of PVC
