It is currently Wed Aug 12, 2026 7:04 pm
PostPosted: Sun Nov 09, 2014 4:33 pm
Why is it that I only see double trailer options for Australia and nothing in the USA ?I am looking to transport more than one kayak and I see that Hobie has a kit for installing more than one kayak on a trailer .Even with the option to put up Three . Is this going to be available in the US or is this only a Au. thing http://slhobie.com.au/images/transport/ ... railer.jpg
PostPosted: Sun Nov 09, 2014 4:35 pm
these are bolt on options and not real expensive 190 for level 3 another 100
PostPosted: Wed Nov 12, 2014 8:54 pm
Bump.Please any responces ?
PostPosted: Wed Nov 12, 2014 10:42 pm
The internet is your friend if you use it.
Here are some of the Trailex trailers (Hobie specs/sells) that will carry more than one kayak......https://www.trailex.com/Canoe-Kayak.cfm
If you search the forum, you will find several trailer set ups that are inexpensive to do/modify by yourself.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Thu Nov 13, 2014 9:34 am
Trailer manufactures have different build requirements in different countries. In the US we have two that allow double loading. Our's are side by side.
38652000 TRAILER HOBIE ALUM KAYAK SINGLE
38652001 TRAILER HOBIE ALUM KAYAK TI SINGLE
38652200 TRAILER HOBIE ALUM KAYAK DOUBLE
38652201 TRAILER ALUM KAYAK DOUBLE DOUBLE (Wide enough to load two Tandem Islands)
38652202 TRAILER ALUM KAYAK PA17
All are Trailex Aluminum Trailers shown in the catalog page 16: http://cdn.hobiecat.com/digital_assets/87367024-international-kayaking-parts-catalog-optimized.pdf
PostPosted: Sun Nov 16, 2014 7:11 pm
ever thought about just having a trailer made?
this is double wide for 2 PA14s, made to my specs and is now a 'stock item' at Float-on. i've helped them design a removable upper tier that will also carry a pair of Outbacks or other similar boats. so 4 kayaks in all.
Cathedra Mea, Regulae Meae.
PostPosted: Mon Nov 17, 2014 8:10 pm
This is a great looking trailer , but I am looking for a double decker due to space issues in storage. Anyone with other trailers please post you pictures and materials used . Thanks :)
PostPosted: Tue Dec 02, 2014 7:53 pm
Is the trailex double-double wide enough to handle two PA 14's?
PostPosted: Wed Dec 03, 2014 9:44 am
Double / Double is wide enough for two Tandem (double) Islands side by side (double).
38652200 TRAILER HOBIE ALUM KAYAK DOUBLE Is wide enough for two islands and easily two PAs side by side. 84” Crossbars.
Width dimensions are in the catalog:
38652000 TRAILEX TRAILER - SINGLE AI / PRO A 12,14
Shown above with AI cradle set option (#72020400) Order cradles separately.
(Crossbars 42” Rear - 25” Forward / 15’ 2” assembled length / 220 lb Capacity).
38652001 TRAILEX TRAILER - SINGLE TI / Pro A 17T
(52” Crossbars / 15’ 6” assembled length / 350 lb Capacity) . Order cradles separately.
38652200 TRAILEX TRAILER - DOUBLE
Shown above with 2 AI and cradle set options (#72020400) and (#38652210) tower system.
(84” Crossbars / 16’ 1” assembled length / 550 lb Capacity). Order cradles separately.
38652201 TRAILEX TRAILER - DOUBLE / DOUBLE
Not shown. Required to carry 2 Tandem Islands or one TI and AI side-by-side.
(96” Crossbars / 16’ 1” assembled length / 550 lb Capacity). Order cradles separately.
PostPosted: Sat Jan 03, 2015 3:21 pm
Yakima kayak trailers are light-duty, but will hold 2 Hobies. Here's one set up with saddles for for a PA12 and an Outback
