It is currently Thu Aug 13, 2026 5:41 am
PostPosted: Wed Feb 11, 2015 4:15 pm
Hello
Would anyone know if the rail clamps that come with the Hobie Powerpole Mount Kit Pro A fit the new 2015 Pro Angler 14 H rail? Thanks
PostPosted: Wed Feb 11, 2015 5:15 pm
Rail clamps? The power pole mounts to a plate on the transom and clamps to the rear handle. Same on the 2015. Does not come with "H-Rail" clamps (the accessory) and is not advised for mounting to the side H-Rail.
PostPosted: Wed Feb 11, 2015 7:03 pm
Hello
Yes Matt, you are correct. I should have said it this way. Would anyone know if the plastic rear handle clamps that come with the Hobie Powerpole Mount Kit Pro A fit the new 2015 Pro Angler 14 rear handle which appears to be the same size and design as the H rails located on the sides of the 2015 Pro Angler 14? Thanks
PostPosted: Thu Feb 12, 2015 8:48 am
I think I answered your question?
The diameter of the handle and the clamps is unchanged from the round 2014 to the 12-sided 2015 "H-Rail".
