It is currently Wed Aug 12, 2026 2:58 pm
PostPosted: Tue Apr 14, 2015 3:19 pm
Hello,
Can someone post close up pictures of the Hobie cradles? I am specifically trying to figure out how they will be mounted to a retrofitted trailer. I am having a custom trailer built, so I want to make sure I see how others have mounted them. I have my cradles on order currently, but hoping to get the manufacturing of the trailer going in the mean time.
Thanks in advance!
Vegasvec
2015 Pro Angler 17t
Lowrance Elite 5 Chirp
Zieman Trailer w/ Cradles
PostPosted: Tue Apr 14, 2015 4:43 pm
https://static.hobiecat.com/item_attachments/72020401z52.pdf
Outer pads cover the bolt holes. The cradles are flat on the bottoms in those areas. Easily mounts to a flat surface.
PostPosted: Sat Apr 18, 2015 5:35 am
Thanks Matt. You answered my question. I was wondering how they were bolted on to the trailer. I assume the pads are installed after the bolt is installed? Also, what is the optimal locations of the cradles?
Vegasvec
2015 Pro Angler 17t
PostPosted: Sun Apr 19, 2015 11:19 am
Yes bolts first then install the pads. On carpeted versions you cut a slit to pass the bolt through.
67" for best fit. These are formed to specific points on the hull.
