It is currently Wed Aug 12, 2026 5:29 am
 Post subject: Lowrance problems
PostPosted: Thu Jun 04, 2015 8:40 pm
Bought a Lowrance x-4 pro last year for hobie pro angler with fish finder kit 3. Worked fine twice then quit working. Sent back to Lowrance and they sent an elite 3. Still won't work. Battery shows full charge on tester. Cut wires and rewired. Still won't work. Any suggestions.
 Post subject: Re: Lowrance problems
PostPosted: Fri Jun 05, 2015 10:14 am
Can/have you tried another transducer?
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Fri Jun 05, 2015 1:42 pm
No. Will transducer cause unit to not come on?
PostPosted: Fri Jun 05, 2015 2:28 pm
A bad transducer connected to most fish finders can cause the unit not to come on or cause damage if there is a short in the transducer wiring. Most brands will let you power up the head unit without a transducer attached. They usually had a simulator mode when no transducer is attached. If you have a spare transducer that you can just plug in to test, that might be an avenue for you to try.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
