It is currently Wed Aug 12, 2026 3:22 am
 Post subject: Rod holder tubes
PostPosted: Mon Aug 24, 2015 8:46 am
Are the rod holder tubes supposed to be water tight. I didn't have a leak on my last PA but on my new 2015 PA-12, I noticed water in the hull after an outing. When I wash the PA water leaks out of the end of the rod holder tubes into the hull. should these tube be water tight.
By the way, I love the upgrades Hobie made on the 2015 PA-12. It now tracks straight w/o a lot of rudder corrections and the H-rail is awesome
 Post subject: Re: Rod holder tubes
PostPosted: Mon Aug 24, 2015 9:31 am
I always find a little water in my PA14s after washing. The bottom rod holders capture the water that runs into them from the floor. I have totally removed those rod holders on my 2012 PA14 to get to side board screws at the front. The tubes are pinched off at the ends. I can't remember if they are totally sealed by the plastic coming together as a tab.
If you're seeing water coming out that pinched area while putting water down the tubes with the front hatch open, then I would take the tubes out and seal the ends. There is a gasket behind the front rod tube plate as well, but it sounds like you are seeing the water come out the pinched ends.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Sun Aug 30, 2015 9:49 am
Pulled the rod tubes out this weekend and filled with water. All four tubes leaked badly.
Sealed with silicone sealant and tested. Now dry when filled.
Just a heads up for those PA owners that are seeing water in their hull after an outing.
PostPosted: Sun Aug 30, 2015 10:57 am
Thanks for confirming what the issue was. I'll bet mine have a similar leak. I might yank mine out and do the same.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
