It is currently Wed Aug 12, 2026 4:27 am
 Post subject: poked a hole in a fin
PostPosted: Sun Aug 30, 2015 2:35 pm
I hit a rock and bent the fin bar, it was sticking out like a completely snapped forearm though skin.
I bent the rod back and it went back into the fin.
Should I be reinforcing that hole?
Gorilla tape?
PostPosted: Sun Aug 30, 2015 4:23 pm
Bicycle tire repair patch. The rubber,glue and patch will hold fine.
PostPosted: Sun Aug 30, 2015 6:34 pm
Gorilla tape is a "magical material".....easy to replace if needed.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Sun Aug 30, 2015 6:52 pm
I've heard marine goop is good as well as using a lighter and melting it closed.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
PostPosted: Mon Aug 31, 2015 7:29 am
I like the suggestion about bicycle tire patch. BUT tape is better for replacing when needed.
PostPosted: Mon Aug 31, 2015 6:23 pm
Thanks It is just a small hole about 4 inches from the bottom of the fin.
I keep Gorilla tap with me when I go out will give that a go if i see any type of tear opening up.
The bicycle tire thing sounded pretty good too.
cron
