It is currently Wed Aug 12, 2026 3:22 am
 Post subject: Pro Angler Seat Question
PostPosted: Sun Sep 06, 2015 7:25 am
I purchased a Pro Angler 14 without a seat. The hull is in new condition.
I do not have the base or anything except the bare hull. I was wondering if anyone had some ideas of how the rig a seat .
PostPosted: Sun Sep 06, 2015 7:47 am
What year is the PA?
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Sun Sep 06, 2015 8:41 am
2012
PostPosted: Sun Sep 06, 2015 10:14 am
Go to PDF page 58 which is catalog page 56 to see what the Hobie P/N's are.
http://cdn.hobiecat.com/digital_assets/ ... atalog.pdf
The seat and parts will be over $300.
I assume the rudder control is already installed....if not, you need to order those parts too.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Sun Sep 06, 2015 12:14 pm
The rudder is installed. I was looking on doing this with after market parts without hobie parts as believe there may be easier solutions
PostPosted: Sun Sep 06, 2015 3:05 pm
Cabelas has a universal seat slide and add any padded bass boat style seat. The slide works great. It will match up to kayak mounting and padded seat bolts to it.
I did this to my older style PA and it was very comfortable. I no longer have the PA air I'd be able to get a pic to you.
You should find info by Googling PA seat slide. It will give you model numbers too.
I just did a quick look and you need the original seat mounting from the PA to make this slide work.
PostPosted: Thu Sep 10, 2015 8:38 am
The seat mount is only 2 pieces of 3" x 1 1/2" aluminum channel.
