It is currently Wed Aug 12, 2026 3:22 am
PostPosted: Thu Feb 04, 2016 11:15 am
Hey guys new member here so hi and really enjoy reading this forum. Im about to purchase a new pa14 and woundering two things. When it comes to sounders which one would u go the dragonfly or hds7 gen 2. Am woundering how u mount the side scan transducer on the hds. Cheers guys
PostPosted: Tue Feb 16, 2016 7:11 am
Just bought my PA12 and first post so take my advice for what's it's worth. My son and I both use Dragonfly 4's and are happy with them. They are very easy to install on the Pro Anglers and all I had to do was grind of the two prongs on the transducer cover and the Raymarine transducer fits very nicely.
I had a Jackson Big Tuna before and the Raymarine transducer was mounted on the RAM side arm. Install on the PA was a breeze and I used a Dremil tool to take the plastic prongs off the transducer cover. The PA has all of the holes pre drilled to running so all of that is already done.
PostPosted: Tue Feb 16, 2016 1:37 pm
I ran the Lowrance GEN2 HDS9 last season, but switching to the new Lowrance ELite Ti7 this season. I used the RAM arm for the StructureScan transducer. Scotty just cam out with a transducer mount that I've switched over to. The RAM unit had a lot of movement and it took a few minutes to get the transducer level every time. With the Scotty unit, I will just have to e drop it down and it should be in the correct position.
Here is the RAM arm.
Here is the New Scotty...I'm still waiting for my new Lowrance Elite Ti7 with the TotalScan transducer to come in.
PostPosted: Mon Feb 22, 2016 1:22 pm
Where did you find that scotty transducer mount? I can't seem to find it anywhere.
PostPosted: Mon Feb 22, 2016 7:21 pm
I ordered this one which I think is the same one.
https://www.austinkayak.com/products/19981/Scotty-Transducer-Arm-Mount-Deck-Mount-140.html
You might try promotion code FB2016b8air which got me 10% off 4 days ago when I ordered.
Jeff
KansasYaker
2014 - Pro Angler - 14 - Upgraded H-Rail Kit
