It is currently Wed Aug 12, 2026 3:22 am
PostPosted: Sun Feb 28, 2016 9:35 pm
Has anyone else experienced broken bungee cords on the foot pedals? I have a 17t and I have this on 3 of the 4 pedals I have. It is annoying because the pedal will not be right side up when I go to out my foot on it. Does Hobie sell replacement cords and if so what is the ideal length you need to cut it to?
Vegasvec
2015 Pro Angler 17t
Lowrance Elite 5 Chirp
Zieman Trailer w/ Cradles
PostPosted: Sun Feb 28, 2016 10:33 pm
Your Hobie Dealer should take care of the broken cord since the PA-17 has a 2 year warranty.
If your Hobie Dealer can't come up with the shock cord quickly, any "Board Kiting" shop carries a wide selection of shock cording and finding the right size should be easy.
A 2 foot length of shock cord will make several repairs to your pedals.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Mon Feb 29, 2016 5:16 am
Yeah...couple times. Just bought a couple feet of 1/8"shock cord at the big box store. A little tricky getting the cord end under the shaft cap ... or tying the knot ... so it tensions at the right length to get the pedal to return to the "ready" position when you want to start pedaling again. Trial & error.
PA 14; 2012
Cape Fear River - NC
PostPosted: Mon Feb 29, 2016 10:08 am
On the PA17T - the shock cord can be positioned on either slot on the pedal to orientate the pedal either for regular or social pedaling. I'm guessing that the cord was left in the standard setting and then was pedaled in social mode so the pedal was being flipped over and stretched the shock cord beyond it's stretching ability. Nothing defective about shock cord - but it is pretty easy to break one.
Jacques Bernier
http://www.hobie.com/
PostPosted: Mon Feb 29, 2016 3:23 pm
Thanks for the info everyone. I found 25ft of shock cord on Amazon for like $7. So I will have it in a few days. No need to hassle the dealer on this one. I have been thinking about using plastic or metal crimped clips instead of a knot. Any thoughts there?
Vegasvec
2015 Pro Angler 17t
PostPosted: Wed Mar 02, 2016 4:34 pm
Hi,
I had similar issues and after a few times replacing the broken/stretch cord, I thought of a better/simpler way
of attaching the cord to the pedals.
I dirlled a 4mm hole in the lower side of the pedal and threaded a short length of shock-cord through, looped it around the pedal shaft
and tied it off. Seems to last longer and when replacing you don't have to muck around with that silly plastic cap on the top of the shaft.
Cheers,
Mike.
PostPosted: Wed Mar 02, 2016 9:50 pm
put one of those adhesive wheel weights on the bottom of the foot pad. should keep it at the right orientation and will be out of sight.
