It is currently Wed Aug 12, 2026 2:18 am
PostPosted: Fri Mar 11, 2016 5:52 pm
I read somewhere that to mount the transducer that there is a kit that you use to adapt it to the lorance ready transducer plate. Does anyone know the part number or if someone else makes it? Also I need ideas of where and how to mount the display. Pics are great and any help at all is wonderful!!! Thanks in advance!!!
PostPosted: Mon Mar 14, 2016 9:43 am
Hobie makes the adapter kit so you can mount a Humminbird transducer. Just Google Hobie Humminbird transducer kit and you will find it. If you have a Hobie dealer close, they will have it as well.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Sun Mar 27, 2016 10:44 pm
The unit you listed does Side Imaging and is a bit larger than the regular 2d sonar ducers. For best side imaging performance the cone angle should not be blocked by anything. Having it in the pocket may cause some hull interference and it might not fit without cutting a hole in the pocket plastic cover. Your yak is plastic so it may not be much interference, but some prefer to mount the SI ducers elsewhere to avoid any issues with interference. I have the Lowrance SI ducer and it is way to long to even fit in that pocket area. Your HB compact SI ducer might fit with some modifications. Check out this older thread - same deal: viewtopic.php?f=78&t=46839
