It is currently Wed Aug 12, 2026 3:16 am
PostPosted: Mon Mar 21, 2016 8:55 pm
Just purchased a power pole micro kit (motor, spike, mounting bracket, wiring harness) and the battery holder that normally fits inside the rear round hatch will not work on a PA12. Any suggestions at to where/how to store the battery while in use? Thanks!
PostPosted: Wed Mar 23, 2016 7:05 pm
Use the bracket that mounts to the mast tube
Sent from my iPad using Tapatalk
PostPosted: Wed Mar 23, 2016 7:07 pm
It fits a 12v8ah battery I also have a 9ah I use for a live well but it won't fit the bracket
PostPosted: Thu Mar 24, 2016 4:29 am
I would recommend using the lithium battery option . This saves having to use a battery in the hull and a big hole drilled for the wire. I used the mast mount shown on the picture for mine before the new battery came out. I would generally get a full day of use out of it with a lowrance hds7 also tied in.
PostPosted: Thu Apr 07, 2016 10:45 am
+1 on the power pole lithium battery. Best invention since the power pole itself!!!
PostPosted: Thu Apr 07, 2016 8:35 pm
+2 on the lithium battery option for the power pole. I already have two 9ah batteries mounted in front for long trips for FF / lights so did not want to add a third.
Keith Black
2014 PA 14 Olive
2014 WS Ride 115x Camo
PostPosted: Mon Apr 18, 2016 10:51 am
+3 on the lithium power pole battery. :D I waited months for that part to be available.
