It is currently Wed Aug 12, 2026 2:06 am
 Post subject: Mirage Drive Lube?
PostPosted: Wed Apr 13, 2016 4:34 pm
I recently purchased a 2016 Pro Angler 12 and purchased some Ceramic Wet Lube by Finishline. Has anyone else here had any experience with this product? Either way, I'll update this thread as I learn more from my experience.
Tight lines to all!
http://www.finishlineusa.com/products/c ... c-wet-lube
 Post subject: Re: Mirage Drive Lube?
PostPosted: Thu Apr 14, 2016 8:48 am
HOBIE MULTI-LUBE
A planet-safe lubricant recommended for lubricating MirageDrives and many other uses. Environmentally friendly for in-the-water applications. Hobie Multi-Lube offers excellent lubrication, is an anti corrosive coating, great for cleaning and many other uses... use on nearly anything that squeaks, rusts, corrodes or binds up; MirageDrives, rudder drums, cams, fishing reels and more. The 1 oz size is perfect for getting the lubricant into tight spaces by using the needle applicator. The 4 oz size has a spray applicator for coating chains and larger surfaces, shafts and bulky parts. Every Hobie owner should have Hobie Multi-Lube.
Be nice to our planet, keep MirageDrives and other components running smoothly and lasting longer without polluting our waterways. Use it for all shop, home and sport lubrication needs.
5120 HOBIE MULTI LUBE 1 OZ
5121 HOBIE MULTI LUBE 4 OZ
