It is currently Thu Aug 13, 2026 5:40 am
PostPosted: Mon Apr 25, 2016 10:00 pm
This is probably a question for Matt, but would like others opinions. Should I store with the rudder and skeg deployed or retracted. Or does it not make a difference. I would think that it probably makes no difference, especially considering I rarely deploy the skeg, unless it is very windy or I am peddling a long way.
STLKayak
2020 Pro Angler 14 360
St. Louis, Missouri
https://www.facebook.com/profile.php?id=100005695487937
PostPosted: Tue Apr 26, 2016 7:16 am
The safest option is "deployed/down" so you take all the tension/pressure off the internal mounting components.
When the rudder is retracted, the internal blocks/fittings are under high tension mounted to "plastic hulls".
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Tue Apr 26, 2016 9:36 am
I agree with Dr. Steelheadchaser. I relieve pressure on everything when I return my PA to the shop where I store it.
I let the rudder down, release the rudder tensioner and the one on the back of my seat, too. I also make sure none of my leashes are being stretched and likewise undo the tiedown cords in the back and on the hatch. I know shock cord can stretch out or rot so I'd like to maximize their life, too.
Basically if it stretches or is under pressure, I release or relieve it. May not make any difference except in my head....but I do it any way.
PA 14 Dune
