It is currently Wed Aug 12, 2026 1:05 am
 Post subject: Downrigger weight
PostPosted: Thu Jun 02, 2016 6:59 pm
What weight are you using with your downrigger? I probably won't be running deeper than 60 feet.
 Post subject: Re: Downrigger weight
PostPosted: Thu Jun 02, 2016 8:26 pm
I think mine is 3-lb, your basic round ball with minimum fins. I have used it down to 120-ft.
PostPosted: Fri Jun 03, 2016 7:00 am
I use the 4# that comes with this one, been fine to 100# at slow (kokanee) trolling speeds:
http://www.cabelas.com/product/ATTWOOD- ... lsrc=aw.ds
been using these for 4 years now and very happy with them, I do re-spool with 80# braid to eliminate the wire humming noise...
2019 Outback360 'Fish Retriever'
2016 i11s 'Go Cougs!'
2012 Oasis and 2012 PA12 (moved on but not forgotten...)
PostPosted: Sat Jun 04, 2016 3:16 pm
Thank you all for your replies. I ended up with a 4# weight because that was what BP had. The next size they had was 10#.
PostPosted: Sat Jun 04, 2016 8:31 pm
Grizz.....Good choice for the weight.....my 4 pound weight actually weighed 4.23 pounds on my wife's digital, 11 pound capacity kitchen scale.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Fri Jun 10, 2016 4:44 pm
I have 4, 6, and 8lb weights. I use the 4lb weight 99% of the time with no issues. I re-strung the downrigger with braid, really helped on the blow-back. Deeper than 50 feet I prefer the 6lb ball, but the 4 does work fine.
PostPosted: Sat Jun 11, 2016 7:34 pm
Dr. SteelheadCatcher, you got me curious. My Bass Pro “Four pound weight” weighed in at 3.86 pounds.
PostPosted: Sat Jun 11, 2016 7:41 pm
Camano14angler, I added 200’ of Scotty Premium Power Braid.
PostPosted: Wed Jun 15, 2016 11:41 pm
6 with braid
