It is currently Tue Aug 11, 2026 9:21 pm
PostPosted: Sun Apr 02, 2017 12:52 pm
Has anyone mounted the Boonedox landing gear on a 2013 or older pro angler 12? It doesn't look like much room to work with. I emailed the manufacturer twice and got no reply. Thanks for any info.
PostPosted: Mon Apr 03, 2017 12:42 pm
Not sure on your application, but when I originally emailed boonedox, I thought I didn't receive a response either so I called them. Turns out they did email me, it was in my junk folder. They are super easy to talk to and you actually talk with a person when you call!
PostPosted: Mon Apr 03, 2017 1:57 pm
I called them and got it worked out. I have a 2013 12ft., and hopefully the H-rail lifter kit will solve any issue I will have mounting it. My order is placed.
PostPosted: Wed Apr 05, 2017 7:51 pm
I have just received my PA14 2017 about a month ago. Got my Boonedox Landing Gear today. Not sure if I got everything. And, with the spacers that I received, the original rail bolts are not long enough. Question: does anyone know: if you order the Landing Gear along with the LGPRO kit for the PA14, should you receive both poles. The pole with the original gear, and the extended pole with the LG
kit?
PostPosted: Fri Apr 07, 2017 6:43 am
I just received my Boonedox landing gear, and it only came with the longer bar. Have not installed yet, hopefully this wknd
PostPosted: Mon Apr 10, 2017 11:37 am
I received both the long and short bar. I ordered the landing gear and the LGPro kit.
