It is currently Tue Aug 11, 2026 10:40 pm
 Post subject: Adding bar to pa14
PostPosted: Sun Apr 23, 2017 10:19 am
Need suggestions to adding bar behind the seat on my 2015 pa 14. How to attach tricks.Image
 Post subject: Re: Adding bar to pa14
PostPosted: Sun Apr 23, 2017 1:50 pm
If you search my name, Matthew Brannon, on Facebook you'll find a detailed post where I installed full length Pro Angler H-Rails to my wife's Outback. I couldn't reach the bolt locations on the inside of the hull so I had to use a toggle style bolt. The installation was quick and easy. The H-Rail is very sturdy!! I have all the info and parts you'd need on that post.
PostPosted: Mon Apr 24, 2017 5:17 am
Matt's (Ring King) example is a very good way to secure the H-Rail. I ended up taking a 21 inch H-Rail kit and make the accessory bar seen here.
https://www.hobie.com/forums/viewtopic. ... ll#p281696
I ended up using a little Marine Goop on the nuts to hold them on the washers and was able to reach the bolts enough to get the nuts started on the ends. Then it was a matter of using a screwdriver on top and a socket wrench with an extension to ratchet it snug. It is a stretch! :D
If you're using the rail that low, it would work fine for rod holders or anything that is going up and not hanging lower than the rail. I wanted mine elevated so the scuppers and the cart would not be impacted and have some room under the tackle tray. You might have to shorten the rail a little looking at your picture. If you leave it as the picture shows, it will impact the taco clip on the left side.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
