It is currently Wed Aug 12, 2026 2:02 am
 Post subject: Hobie PA-14 Cradle Set
PostPosted: Wed May 17, 2017 9:21 am
I see where these cradles are now sold with carpet already installed, versus the gray foam pieces. Question: I am wanting to put carpet on my cradles (for obvious reasons)..........do I need to remove these gray foam pieces before adding the carpet, or do I simply install (glue) the carpet over the gray foam pieces?
PostPosted: Wed May 17, 2017 4:55 pm
PA 14 cradles are still coming with the foam pads, not carpet. Here's a current photo of the set:
Howie Strech
PostPosted: Wed May 17, 2017 11:57 pm
I've seen a few companies online that are selling the cradles with carpet already installed. Regardless, if I wanted to add carpet, should I remove the gray foam pieces or glue the carpet over the gray foam pieces? Which is the preferred option?
PostPosted: Sun Jun 25, 2017 5:06 pm
My PA 14 is wearing the white fiberglass of the cradles which are in return rubbing on the hull. I think thicker pads would do the trick, if they exist. I am also thinking of gluing carpet or something on top of the original pads. Any thoughts would be great. Some of my friends are using PVC pipe but I recall Hobi only recommended the cradle.
