It is currently Wed Aug 12, 2026 2:30 am
PostPosted: Mon Feb 26, 2018 6:15 am
I need to replace my broken off forward drive pull lever on Mirage 180. I guess I can get under warranty from hobie, but thing broke under screw nut, so how do I get broken threads out of plastic housing when break is flush with it?
PostPosted: Mon Feb 26, 2018 8:43 am
1. Use a screw extractor
2. Take it to your dealer
8)
PostPosted: Mon Feb 26, 2018 9:18 am
The new V2 style is a complete replacement kit with larger (5/16") threads - so you will get new levers as well as the tendons. Talk to your dealer and they'll file a claim for you.
Jacques Bernier
http://www.hobie.com/
PostPosted: Mon Feb 26, 2018 11:46 am
Thanks all, I talked to dealer and sent photo, he emailed back that warranty claim filed with Hobie. PA12 is about 9 months old.
PostPosted: Wed Mar 07, 2018 6:54 pm
After dealer submitted warranty claim I received at home both shift levers as complete set with plastic arm it screws into (item #'s 81486021 & 814910021). It was very easy install and I believe it will work well.
However, they also sent me new fins; "MD180 V2 Boom-Mast-TBO Fin Kit Iten # 81501112". These are different than my existing fins, these fins connect to drive with pin and split rig, whereas the existing fins connect via a screw through top of fin into cutout window in fin. My dealer is perplexed so are the new fins upgrades or old stock they sent me by mistake?
