It is currently Wed Aug 12, 2026 12:21 am
 Post subject: Hull integrity issue
PostPosted: Sat May 11, 2019 3:24 am
Hi guys, just purchased a second hand PA-14 kayak. It has a scuff abrasion damage on hull from what seems to be from kayak trolley wheel. Hull integrity is still sound but scuff area has light visibility from inside. My questions; do i have a potential future problem? And how is the best way to repair it? Thganks invadvance for youd advice.
 Post subject: Re: Hull integrity issue
PostPosted: Mon May 13, 2019 2:50 pm
The plastic is somewhat translucent and more so as it gets thinner. If you can press the area without much deflection it should be OK. There is no repair that is reasonable at this point.
PostPosted: Fri May 17, 2019 2:39 am
Thank you Matt it is as you say little deflection. Wanted to be sure thanks for confirmation.
