It is currently Tue Aug 11, 2026 4:23 pm
 Post subject: Rudder Steering Noise
PostPosted: Tue Jan 22, 2019 11:14 am
Hello. My rudder steering handle on my 2016 PA 14 is making a noise when I turn it right similar to (for lack of a better analogy) an old spring being stretched out (or an old screen door with a spring opening). But it's only making this noise on the right side (I have steering levers installed on both sides). The left side isn't making this noise. It doesn't matter whether I'm in the water or out. I'm pretty sure the noise is coming from inside the hull underneath the steering handle.
Any thoughts on what this noise is?
Many thanks!
PostPosted: Tue Jan 22, 2019 1:09 pm
Many thanks!
There is a spring on the bottom of the metal rudder shaft for each side. Compare the good and bad side to make sure the spring is aligned properly. That might be the cause of the noise.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Fri Mar 15, 2019 8:02 am
Turned out I had too much tension on the rudder cable. Thanks for the input.
