It is currently Tue Aug 11, 2026 4:22 pm
PostPosted: Tue Feb 05, 2019 6:17 am
I’ve been fishing in an Outback for 10 years and finally upgraded to a PA 12. Deciding on Depth finder now, side imaging and map creation are essential and I’m leaning towards Humminbird or Garmin over Lowrance. I see a transducer adapter is available for Humminbird but that states side imaging may be impacted. Is this relevant to the 2019 model or prior ? I’m hoping this limitation was addressed with the new model changes and I’m able to use Garmin or Humminbird side imaging as well, would like conformation before deciding.
PostPosted: Wed Feb 06, 2019 7:17 am
No limitation with the Hobie Guardian...
François - French Hobie fishing team - Outback 2019 papaya
ex: Revo 13 2007 - PA 14 2008 - PA 12 2009 - Outback 2011/2013/2015 - Compass 2017
PostPosted: Wed Feb 06, 2019 3:42 pm
Thank you
PostPosted: Wed Feb 20, 2019 5:31 pm
I’m a little late to the party, but don’t limit yourself by mounting the transducer on the bottom of your PA 12.
Attach it from the very rear transom H-rail. Then you can have side imaging all you want, as well as run your kayak up into the launch shallows without concern of dragging the hull mounted transducer.
PostPosted: Wed Feb 20, 2019 10:43 pm
If you fish shallow water as your transducer would drag the bottom, then you don't need a fishfinder...
